Use the following procedure to display status information about the OVSDB controller.
- Select OSVDB.
- Select the Status tab.
Status Field Descriptions
Use the data in the following table to use the Status tab.
Name |
Description |
IpAddress |
Displays the IP address of a controller. |
Protocol |
Displays the communications protocol of a controller as TCP or SSL. |
Port |
Displays the communications port for the controller. Value range of 1 to 65535. |
Source |
Displays the source of the controller as learned or configured. |
OperStatus |
Displays the operational status of the controller. |
